Managing Data Sources
This feature allows you to manage the Data Schemas registered with MMG. The Data Source Summary window shows the list of Data schemas registered with MMG. These Data schemas can be used either for workspace or for sourcing data. Click Data Source Summary to navigate to Data Source Summary window.
This window also allows you to manage these registered external sources.
The Data Source Summary is divided into two sections: Used Data Source and Unused Data Source.
To view the Data Source details., Click Action next to corresponding Workspace and select View
- Used Data Source: This shows the list of Data Sources registered with any workspace. Here, you can only view the Data Source details. The count of Used Data Sources also displayed at the top of Data Source Summary page.
- Unused Data Source: This shows the list of Data Sources those are not registered with any workspace. Here, you can only view, edit, or delete the Data Source details. The count of Unused Data Sources also displayed at the top of Data Source Summary page.
- Navigate to Workspace Summary window.
- Click Data Source Summary to navigate to Data
Source Summary window and click Add
Datasource
The Add Data Source window is displayed.
- Navigate to Data Source Summary window.
- Click Add Datasource .
For more information, see the Create a Workspace section.
