Currency Conversion Algorithms
The following table lists the currency conversion algorithm types shipped with the product:
| If you want to use... | Then create algorithm using the following algorithm type.... |
Date based exchange rate during currency conversion while:
C1_CURALGBS |
C1_CURALGAD |
C1_CURALGPY |
| Date based exchange rate during currency conversion while aggregating transactions | C1_CURALGTFM |
Date and time based exchange rate during currency conversion
while:
C1_EXCRTBS |
while:
C1_EXCRTAD |
while:
C1_EXCRTPY |
| Date and time based exchange rate during currency conversion while aggregating transactions | C1_EXCRTTFM |
Currency conversion for FT GL extension in the following
financial transaction (FT) types:
FTFREZGLEXTN |
| Fetching the exchange rate available corresponding to the transaction in the CI_TXN_DETAIL table. | C1_EXCRTOVRD |
Parent topic: Currency Conversion
