Defining General Ledger Divisions
There are two types of divisions referenced in the system: a GL Division and a Division. This is a rather powerful structure, but it can be confusing.
- General Ledger (GL) Division - GL divisions typically comprise individual entities (e.g., companies) in your general ledger. You must set up a GL division for each such entity. The GL division's sole purpose in the system is to define the accounting period associated with financial transactions linked to contracts associated with the GL division (contracts are associated with GL divisions via their contract type). The system cares about accounting periods in order to prevent a user from booking moneys to closed periods. It also uses accounting periods when it produces the flat file that contains the consolidated journal entry that is interfaced to your general ledger (refer to The GL Interface for more information).
- Division - A division is typically associated with a jurisdiction. The definition of a jurisdiction is a geographic-oriented entity with unique business rules. For example, if you conduct business in California and Nevada, and each state has different collection rules, you will need a separate jurisdiction for each state. You must set up a division for each jurisdiction in which you conduct business.
To define a general ledger division, select Admin Menu, General Ledger Division.
Description of Page
Enter a unique GL Division for the general ledger division.
Enter a Description of this general ledger division.
Define the accounting Calendar ID that controls how to convert an FT's accounting date into an accounting period. Refer to Defining Accounting Calendars for more information.
You may define a Currency Code for the GL division. Note that the system does not use this currency code.
Where Used
Follow this link to open the data dictionary where you can view the tables that reference CI_GL_DIVISION.
