Recommending a Product for a Deal
Prerequisites
To recommend a product for a deal, you should have:
Products defined in the application
Procedure
To recommend a product for a deal:
Ensure that the Product section
is expanded in the Deal zone when you are defining
a deal.
The Product section contains the following field in a grid:
Field Name Field Description Mandatory (Yes or No) Product Used to indicate the product that you want to recommend for the deal. Note:The Search (
) icon appears corresponding to the Product field. On clicking the Search icon, the Product Search window appears.
On specifying the product, the description of the product appears corresponding to the Product field.
No Note:The system automatically derives recommended products for the deal when the questionnaire contains questions where the question applicability is set to Package and Product Reference.
The system derives the recommended products from the reference deals. It only considers automatically recommended products of the reference deals and not manually recommended products of the reference deals.
- Enter the required details in the Product section.
If you want to recommend more than one product for the
deal, click the Add (
) icon and then repeat step 2.
Note: However, if you want to remove a recommended product from the deal, click the Delete () icon corresponding to the product.
Click Save.
The products is recommended for the deal.
Related Topics
For more information on... | See... |
How to define a deal | Defining a Deal |
Deal zone | Deal |
