Defining Rate Components
CAUTION: We strongly recommend that you familiarize yourself
with the information under Designing Rate Components before using this transaction.
Rate components control exactly how your bill calculation lines are calculated. Every rate component exist in respect of a given rate version. This is because the rate version defines the date on which all of its rate components become effective.
Copying, delete and moving rate components. You can
use the rate component maintenance transaction to duplicate, delete
and move rate components. However, you may find these functions are
easier to do using the Rate Version
Merge transaction as this transaction can copy en masse and
it also updates the relevant cross reference information if you move
or delete a rate component.
The topics in this section describe how to maintain a rate component.
Don't forget to finish the rate version.  After you
have added all necessary rate components to a rate version, don't
forget to return to Rate Version
- Main and change the state of the rate version to  Finished (otherwise, it cannot be used by billing).
Related Topics:
Parent Topic: Rates
