Rate Component - Cross Reference
Minimum charge, maximum charge, exact charge, apply-to, and summary rate components reference other rate components. For these types of rate components, open Main Menu, Rates, Rate Component and navigate to the Cross Reference tab define the other rate components to which it refers.
Description of Page
Rate Component contains a concatenation of basic information about the rate component. This information only appears after the rate component has been added to the database. The adjacent up and down arrows cause the rate component immediately before or after this rate component to be displayed.
Use the Apply this Rate Component to collection to specify the other rate component(s) on the Rate Version to which the rate component in question should refer. The list of rate components available for reference is displayed on the right. Use the left arrow to move the desired rate components into the grid. If a rate component appears in the apply to list in error, use the left arrow to remove the rate component.
Fastpath:
Refer to Editable Grid in the system wide standards documentation for more information about adding records to a collection by selecting from a list.
An apply to rate component that has a charge type of unit rate can only reference SQ, item, interval pricing and calculation rate components. Apply to rate components with a charge type of percentage, along with summary, minimum charge, maximum charge and exact charge rate components can reference all types of rate components including summary.
The This RC is referenced by collection indicates what other rate components reference the rate component in question.
