Installing the Customer Display with Pole Mount on a Cash Drawer or Other Surface
Figure 5-6 Customer Display with Pole Mount
Tighten the pole base plate captive screws, if required. Guide the cable through an opening in the base plate.
Attach the Customer Display with Pole Mount to the cash drawer or other surface using the four #8-32 base plate screws included in the Customer Display with Pole Mount box.
To attach the Customer Display with Pole Mount to a cash drawer or other surface with a cable routing hole:
Tighten the pole base plate captive screws, if required. Guide the cable through cable routing hole.
Attach the Customer Display with Pole Mount to the surface using the four #8-32 base plate screws included in the Customer Display with Pole Mount box.
For configurations without the Peripheral Expansion Module, connect the Customer Display with Pole Mount cable to the Workstation 820 USB(CFD) port.
For configurations with the Peripheral Expansion Module, connect the Customer Display with Pole Mount cable to the Peripheral Expansion Module USB(CFD) port.
