11 POS Operations and KDS Sharing the Same Client
Microsoft Windows 32 clients support having the POS and the KDS Display on the same physical device. Operators can switch between the POS and the KDS using a function key on the workstation and the KDS toolbar respectively. You can configure the default screen location of POS and the KDS Display so operators can view them side by side. When the focus is on the KDS Display, operators cannot switch to the POS when it is minimized to the system tray.
Oracle Hospitality recommends upgrading your clients to Simphony version 3.0 prior to configuring this feature.
