Configuring a KDS Display to Run on the Same Client as a Workstation
  1. Select the property, click Setup, and then click KDS Displays.
  2. Double-click a KDS Display record to open it.
  3. Click the Layout tab, and then configure the following settings:
    • From Top: Enter how far from the top, in pixels, to place the KDS window on the workstation screen.
    • From Left: Enter how far from the left, in pixels, to place the KDS window on the workstation screen.
  4. Click the General tab, scroll to the Options section, and then select 11 - Always Hide Frame.
    Enabling this option hides the KDS Display window frame when the KDS Display UI is not in full-screen mode.
  5. Click Save.
  6. Add the Show OPS function to the KDS toolbar to allow workstation operators to switch focus back to the POS client. See Configuring the KDS Toolbar for instructions.
