21 Runner Chits
Food runners assist servers in running food from the kitchen to customer tables. A runner chit is a piece of paper that prints at a printer, allowing a food runner to know where to take the items (which table), which items to present, and to which guest (seat number). Runner chits print on Expo Done, Prep Done, or All Prep Done.
Figure 21-1 Runner Chit with Check ID
In Simphony version 18.1 and later, runner chits show the guest check ID (if available) on the top right corner of the header, instead of the guest check number. If a guest check ID is unavailable or is configured to be suppressed, the check number prints instead. For instructions on how to set up a runner chit printer for a KDS, see Creating a KDS Order Device.
Figure 21-2 Runner Chit with Check Number
