Printing Runner Chits by Order Type
You can configure runner chit printers to print a chit for each individual item by order type. If runner chit printers are assigned by the KDS order device, chits print to the runner chit printer assigned to the last KDS the item was bumped from. The chit prints when the cook bumps the item from the KDS Display. If the item routes to multiple Prep Stations, the runner chit prints when it is bumped from the last KDS station .
  1. Select the Enterprise, property, revenue center, or zone, click Setup, and then click Order Type Parameters.
  2. For the appropriate order type, select option 9 - KDS Allow Item Print on Item All Prep Done, and then click Save.
  3. Select the revenue center, click Setup, and then click Order Devices.
  4. Double-click the appropriate KDS record to open it.
  5. Click the Options tab, select 29 - Item Print on Item All Prep Done, and then click Save.
    You must enable Order Devices option 29 for this feature to work.
