17 Workstation Alerts for Unsuccessful Sending to Order Devices
When POS client tablet devices lose wireless network connection. The workstation operator can return to the range of Wi-Fi coverage to ensure that items are sent to the order device/KDS.
When the kitchen printer runs out of paper. The workstation operator can add a paper roll to the printer.
When the KDS Controller or Print Controller is powered off. The workstation operator can start the KDS/Print Controller.
Important:
A flashing Alerts button appears on the POS client device only when the system does not receive confirmation that an order was successfully sent to an order device/KDS. The workstation operator must then confirm that the items did not reach the kitchen, and notify the kitchen of the items that were not successfully sent. If the order is not successfully received by the KDS Controller, you should consider the order lost, as the order is not automatically sent again once the KDS system’s communication is restored.-
When redirects or backups are configured for the KDS Controller or Print Controller. Alerts appear when the backup or redirect order devices are down.
When any device serving as a KDS Display is offline or powered off.
When Dynamic Order Mode (DOM) is enabled and the DOM Type is set to Fire On Fly or Fire On Next. When DOM is enabled and the DOM Type is set to Fire On Tender, alerts will appear when tendered. Configuring a KDS Order Device contains more information on the DOM Type configuration.
For Timed Fire and Autofire items. Alerts appear for these two types when the order is fired.
