Disabling Load Balancing and Enabling Capacity Scheduling
KDS load balancing is not supported when using KDS Capacity Scheduling.
  1. Select the property, click Setup, and then click KDS Controllers.
  2. Double-click the KDS Controller record to open it.
  3. On the General tab, deselect 8 - Enable Load Balancing, and select 13 - Enable Capacity Scheduling.
  4. Click Save.
