Setting the Relative Capacity for Each Order Device
The following steps describe how to set the relative capacity for configured order device panels in the KDS Display.
  1. Select the property, click Setup, and then click KDS Displays.
  2. Select the KDS display record, and then click the Display tab.
  3. In the Display Screen Options section, set the appropriate capacity value in the Panel Configuration table for each configured panel.
  4. Click Save.
