Deploying the Media Viewer CAL Package
  1. Select the Enterprise, click Setup, and then click CAL Packages.
  2. Select Media Viewer from the left pane.
  3. Click the Deployment Schedule tab, and then click Add Deployment.
  4. From the Deployment Type column, select 2 - Specific Service Host.
  5. From the Service Host column, select the service host to download the CAL package, and then click OK.
  6. Click Save.
