Configuring Order Device Routing By Guest Check Amount
You can route orders to order devices based on the guest check amount. The "whole-total" guest check amount is used irrespective to any tenders applied to it.
To use this feature,
you need to assign print classes to Tender/Media records. With a Below Threshold Print Class assigned and Order
Routing Threshold Amount set:
Orders below the threshold use the Tender/Media's Below Threshold Print Class.
Orders at or above the threshold use the Tender/Media's Print Class.
Order device dynamic routing works with load balancing. This feature does not support DOM.
Parent topic: Basic Kitchen Display System (KDS) Configuration
