Language Translation Configuration Tasks
Configuring language translation in Simphony consists of completing
the following tasks:
Table 9-1 Overview of Configuring Languages
| Task | Go To |
Set the Translation Privileges |
Create an Enterprise language entry |
Load translation file |
Translate definition data |
Set languages for the property |
Assign languages to employees |
Set the default language for a workstation |
(Optional) Configure Simphony to print a secondary language on guest checks and customer receipts |
(Optional) Create touchscreen button to switch between languages on workstations |
Related Topics
- Language Settings and Translation
- EMC Record Translation
- Configuring Translation Privileges
- Configuring Languages
- Configuring Workstation Translations
- Configuring the EMC Translation Files
- Translating Menu Item Records
- Translating Touchscreen Buttons
- Setting Languages for the Property
- Setting the Default Language for a Workstation
- Configuring Screen Language Buttons
- Copying Translations from One Language to Another
- Exporting a Translation File
Parent topic: Language Settings and Translation
