Copying Translations from One Language to Another
- Select the Enterprise, click Setup, and then click Languages.
- Double-click the appropriate language record to open it, and then click the Translations tab.
- To copy all translations from another language, click Copy All Translations, select the language from which to copy, and then click OK.
- To copy the translations for selected elements:
- From the Text Element section, select the relevant records, and then click Copy Selected Translations.
- Select the language from which to copy, and then click OK.
- Click Save.
Related Topics
- Configuring Translation Privileges
- Configuring Languages
- Configuring Workstation Translations
- Configuring the EMC Translation Files
- Translating Menu Item Records
- Translating Touchscreen Buttons
- Setting Languages for the Property
- Setting the Default Language for a Workstation
- Configuring Screen Language Buttons
- Exporting a Translation File
- Language Settings and Translation
- Language Translation Configuration Tasks
- EMC Record Translation
Parent topic: Language Settings and Translation
