Setting the Default Language for a Workstation
You can configure the language that appears on the POS UI Sign-In page.
Employees with a different language configured see their default language after signing in to the workstation.
The CAPS workstation requires the translation files, so the ad hoc reports for the workstation operator who is signed in show the report in the his or her assigned language.
- Select the property, click Setup, and then click Workstations.
- Double-click a workstation record to open it.
- On the General tab, select the Language to appear on the workstation device, and then click Save.
- Repeat Steps 2 and 3 for all workstations.
Related Topics
- Configuring Translation Privileges
- Configuring Languages
- Configuring Workstation Translations
- Configuring the EMC Translation Files
- Translating Menu Item Records
- Translating Touchscreen Buttons
- Setting Languages for the Property
- Configuring Screen Language Buttons
- Copying Translations from One Language to Another
- Exporting a Translation File
- Language Settings and Translation
- Language Translation Configuration Tasks
- EMC Record Translation
Parent topic: Language Settings and Translation
