Configuring the SVS Service Charge Records
You can configure up to four service charge records for use with the SVS Processor plug-in for gift card service. The services charges are:
SVS Issue SVC Charge
SVS Activate SVC Charge
SVS Reload SVC Charge
- Select the Enterprise, property, or zone, click Configuration, and then click Service Charges.
- Insert a record, name it SVS Issue SVC Charge, and then click OK.
- Double-click the record to open it.
- Select option 14 - Service Charge Used For Stored Value Transactions.
- Set other Service Charge fields and options as needed. Configuring Service Charges contains more information about the fields and options.
- Click Save.
- Repeat steps 2 through 6 to create the remaining service charge records, following a similar naming convention (for example, SVS [Service Charge name] SVC Charge).
Parent topic: Stored Value Solutions (SVS) Processor
