Configuring the SVS Discount Record
You must create a discount record for use with the SVS Processor plug-in for the gift card service. The discount is used to implement the optional SVS Bonus Gift Card.
  1. Select the Enterprise, property, or zone, click Configuration, and then click Discounts.
  2. Insert a record, name it SVS Bonus GC Redeem, and then click OK.
  3. Double-click the record to open it.
  4. Set other Discount fields and options as needed. Configuring Discounts contains more information about the fields and options.
  5. Click Save.
