From the desktop of each server running CAPS on IIS, select Start, Control Panel, Administrative Tools, and then select Internet
Information Services (IIS) Manager.
From the IIS Connections column, expand the Sites folder and right-click the site created for IIS
CAPS and select Remove. The name of the IIS
CAPS site should be the same as the ServiceHostName.
For example, if your service host name is MyIISCapsSvcHost, your site
name should be added using the exact same text.
Figure 1-2 IIS CAPS Site
From the IIS Connections column, click Application
Pools.
Figure 1-3 Simphony Application Pools
Right-click the application pool created for IIS CAPS and
select Remove. The name of the IIS CAPS pool
should be the ServiceHostName Pool. For example, if your
service host name is MyIISCapsSvcHost, your IIS CAPS
application pool name should be MyIISCapsSvcHostPool.
