Post-Upgrade Steps for CAPS on IIS for Simphony 2.9 Users
This section applies only if you are upgrading from the Simphony 2.9 General Release (GR) to a higher release. Review the Oracle Food and Beverage Compatibility Matrix and Oracle MICROS Simphony Release Notes for information about system requirements.
Beginning with the Simphony 19.1 release, Microsoft SQL Server is no longer supported as a database platform.No additional post-upgrade steps are necessary for CAPS on Microsoft Internet Information Services (IIS) if you upgrade from Simphony releases later than Simphony 2.9 GR.
- Step 1 - Close and Post All Transactions
- Step 2 - Access the IIS Manager Console
- (Optional) Step 3 - Rename the IIS Folder
- (Optional) Step 4 - Enable an Option and Configure CAPS
- Step 5 - Stop IIS
- (Optional) Step 6 - Move the DbSettings.xml to the Newly Defined IIS CAPS Path
- Step 7- Start IIS
- Step 8 - Verify Log Creation, Database Tables, and Delete the Old Directory
Parent topic: Upgrading Simphony
