(Optional) Step 6 - Move the DbSettings.xml to the Newly Defined
IIS CAPS Path
IIS CAPS Path
This step is not required if you are performing an upgrade.
Copy the DbSettings.xml file from
the old path (review Step 3 - Rename the IIS Folder, and verify the
default CAPS IIS installation path), and then using Microsoft Windows
Explorer, navigate to that path (for example, [Drive]:\Simphony2\IISCAP_Backup\IISCAPS\DbSettings.xml).
Paste the DbSettings.xml file in
the new path: [Drive]:\Simphony2\EgatewayService\IISCAPSServiceHost.
Edit the DbSettings.xml file to
update the CAPS database password; this means to delete the previously
existing password value on epw (encrypted format) and enter the password
again with pwd (ClearText). For example:
