This step is not required if you are performing an upgrade.
Rename the Simphony release 2.9 (or later) IIS CAPS folder.
Verify the installed folder path by navigating to the [Drive]:\MICROS\Simphony2\Tools\CAPSConfigurator\CAPSConfigurator.exe.config file and open it with a text editor such as Microsoft Notepad.
Note that the default Simphony release 2.9 (or later) IIS
CAPS folder location is: [Drive]:\Simphony2\IISCAPS. Rename the IISCAPS folder to IISCAP_Backup. This step ensures that you maintain a
backup of the old folder.
