(Optional) Step 4 - Enable an Option and Configure CAPS
This step is not required if you are performing an upgrade.
Access EMC and navigate to the Enterprise level, click
the Configuration tab, and then click Roles.
Click your assigned role and switch to Form view.
Click the Operations tab, and then
click the Miscellaneous subtab.
In the Miscellaneous Options section, enable 10065 - Download Software, Install and Authenticate Clients and Service
Hosts Using CAL, and then click Save.
If you are configuring CAPS on IIS at the Simphony application
server, you can access the CAPS Configurator Tool using this path: [Drive]:\MICROS\Simphony2\Tools\CAPSConfigurator\CAPSConfigurator.exe. If you are installing CAPS on IIS
on a remote workstation or virtual machine, install CAL on that device,
and through CAL, deploy a package called CAPSOnIIS to the device. When the software is on the device, navigate to [Drive]:\MICROS\Simphony\CAPSOnIIS\Tools\CAPSConfigurator\ and double-click the CAPSConfigurator.exe file.
Log on to the CAPS Configurator Tool, and freshly configure CAPS with the default configuration settings
by clicking the Configure CAPS button.
Figure 1-7 CAPS Configurator Tool
Upon successful installation, verify that the new directory
is created along the [Drive]:\Simphony2\EgatewayService\IISCAPSServiceHost path.
