Step 8 - Verify Log Creation, Database Tables, and Delete the Old Directory
- Verify that logs are created here:
[Drive]:\Simphony2\EgatewayService\IISCAPSServiceHost\EgatewayLog. - Verify that the tables are upgraded on the existing transaction database.
- Delete the Simphony release 2.9 CAPS directory (for example, the IISCAP_Backup directory). See Step 3 - Rename the IIS Folder for details.
