Refilling Menu Items
  1. Pick up a check from the previous service round from the Open Check SLU.
  2. To directly refill the items, select the menu items to refill from the check, and then press the Refill Auto function key or the Refill Interactive function key.
  3. To refill items from a list or to view a list of all refillable items on the check:
    1. Press the Refill Auto function key or the Refill Interactive function key without selecting any items on the check.
    2. From the Select Items to Refill dialog, select the items to refill, and then press Refill.
    3. To close the dialog, press Close.
  4. If an order quantity was specified when adding a menu item in the first round, enter the number of refills when prompted.
    For example, if a party of four ordered 4 glasses of Orange Juice in the first round, when you attempt to refill the order, the workstation prompts you to enter the number of refills. The initial menu item quantity is taken as the maximum quantity (in the aforementioned example, the maximum quantity is 4 when refilling).
    When refilling multiple menu items with quantities, you must enter the refill quantity in the order that the menu items appear on the check. That is, the first entered number of refills is taken as the refill quantity of the first menu item, the second entered number of refills is taken as the refill quantity of the second menu item, and so on.
Related Topics
