Splitting Off Items from a Suites Check
- Press the Pickup Suites Check function key, enter the suite number, and then select the Suites check to split.
- Press the Touch Split function key, and then move the items to be paid by another guest to the new Suites check.
- Press Save, and then press Yes when prompted for confirmation.
- If you are prompted for confirmation to print the new Suites check, press Yes.
- Make the changes, and then end the current service round of the original Suites check that is open on the check detail area.
- Add suites owner information to the new check. For instructions, see Adding Suites Owner Information to a Check.
Parent topic: Menu Items
