12 Troubleshooting CAL and DCAL
The Simphony Installer provides the ability to switch an Enterprise URL during the application server upgrade. When the Enterprise URL changes, the SimphonyInstall.xml file included within existing CAL packages becomes out-of-date. Existing CAL packages (from a previous upgrade) that are still being deployed must be manually reloaded. The McrsCAL and ServiceHost are the only Oracle CAL packages that include this file.
Make a backup copy of the current SimphonyInstall.xml on the application server before reloading any CAL packages in case the file is accidentally overwritten. Viewing, Reloading, and Saving CAL Package Contents contains more information.
Simphony Release 2.9
Simphony Release 2.10
Simphony Release 18.1
- Deploying ServiceHost Hotfixes with DCAL
- DCAL Workstation Computer Name
- Upgrading CAL on Simphony 2.8 Clients or Later
- Re-configuring CAL with an Existing Simphony Client Install
When re-configuring CAL on a workstation with Simphony client already installed, ServiceHost may not be able to authenticate to the application server. - ServiceHost Deployment Using DCAL Prior to Simphony Release 2.8
- ServiceHost Upgrades Prior to Simphony Release 2.8
- ServiceHost Package Install Loop
- Upgrading DCAL Workstation from Releases Prior to Simphony 2.9.3
- Changing the CAL URL
