Re-configuring CAL with an Existing Simphony Client Install
When re-configuring CAL on a workstation with Simphony client already installed, ServiceHost may not be able to authenticate to the application server.
Recommended workaround:
Workstations should be re-imaged using the manufacturer supplied factory recovery mechanism.
Applies to: All Simphony Client versions
Parent topic: Troubleshooting CAL and DCAL
