Upgrading CAL on Simphony 2.8 Clients or Later
When upgrading to CAL client versions 141 through 145 from versions prior to 139, an existing Simphony 2.8 client authentication is not used and users are prompted for their EMC logon credentials.
Workaround #1:
The user must enter a username and password of an employee with Role privilege 10065 enabled as described in Configuring Employee Privileges for Using CAL.
Workaround #2:
Deploy CAL 139 or 140 before deploying versions 141 through 145.
Workaround #3:
Reconfigure CAL without changing the Workstation Identity. Changing the CAL URL contains more information.
Applies to: CAL client versions 141 through 145.
