Order Handling on Open Checks
Simphony allows you to control when menu items on open guest checks
are sent for preparation to order devices, such as remote printers
or a kitchen display system (KDS) system. You can:
Send orders while remaining on the guest check without having to pick up the check again or sign back into the workstation
Take orders for an entire service round, but hold the items and send them in groups over a period of time
Program the workstation to automatically send items or an entire order at a preset time
Choose to send items on hold to order devices or keep them on hold when ending the current service round
Manually fire menu items within the current round to order devices
Void a previous round fired item
Cancel a transaction and have only the non-fired items cancelled, while previously fired items in the current service round remain on the check
Related Topics
- Sending Items to Order Devices While Remaining on the Check
- Re-firing Items to the Order Device
- Holding Menu Items on a Check
- Holding Selected Items or an Entire Order for a Preset Time
- Ending the Current Round and Closing Checks with Items on Hold
- Combining Checks in the Same Revenue Center into One Order
- Combining Checks Across Revenue Centers into One Order
- Indicators on the Employee Check Journal Report
Parent topic: Guest Checks
