Suspend and Resume
With the Suspend and Resume feature, workstation operators can:
Suspend a check started by another employee, and sign on to the workstation.
Suspend a check when the workstation automatically signs off an employee.
Suspend a check using a Service Total key.
When suspended, the check is stored in the memory until a workstation operator resumes it by signing on to a workstation.
