PreviousNext
JavaScript must be enabled to correctly display this content
Configuring Suspend and Resume
Select the revenue center, click Setup, and then click RVC Parameters.
Click the Options tab, and then
select 60 - Enable Suspend/Resume.
Click Save.
Select the Enterprise, property, or zone, click Configuration, and then click Tender/Media.
Insert a record with the tender name.
Double-click the tender record.
On the General tab, select 2 - Service Total from the Key Type drop-down list.
click the Ops Behavior subtab.
Select 74 - Suspend Order.
Click Save.
Select the Enterprise, property, revenue center, or zone,
click Setup, and then click Tender
Parameters.
Click the Configuration tab.
To configure a default Suspend Order tender, in the Default Suspend Order Tender drop-down list, select the
suspend order tender.
A default Suspend Order tender is needed for certain suspend
scenarios, such as when a workstation operator is auto-signed out
or when another operator signs in.
