Creating a Suspend and Resume Button
To allow workstation operators to manually suspend a check, you need to add a button assigned to the service total tender record.
- Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Page Design.
- Open the page on which to place the Suspend/Resume button.
- On the Edit tab, select the page area in which to define the Suspend/Resume button.
- Click Button.
- On the General subtab, enter the button name in the Legend field.
- Select Tender/Media from the Type drop-down list.
- Click the black arrow directly beneath the Type drop-down list, select the tender you created for the suspend and resume service total, and then click OK.
- Position and size the button on the page. Use the Style arrow to change the color.
- Click Save.
Parent topic: Suspend and Resume
