Configuring Banquet Guest Check Buttons and Prompts
To configure the Begin Banquet Guest Check for workstation touchscreens:
Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Page Design.
You can configure an existing touchscreen or add a new one. Add a new button.
Figure 34-2 Page Design – Add Button
From the Type drop-down list, select Function, select the Begin Check By Prompt function, and then click OK.
Figure 34-3 Page Design – Begin Check By Prompt Function
Click the Configure Prompt Details button.
Figure 34-4 Page Design – Configure Prompt Details
Option 1 – Clicking the ‘No’ Button
Click No when prompted.
Figure 34-5 Configure Prompt Details ‘No’ Response
From the Prompt Details section, configure the following:
From the Prompt Type field, select Configurable.
From the Dialog Type field, select a type from the drop-down list.
From the Prompt Category field, select BanquetPrompt.
From the Prompt Title field, select a title category from the drop-down list.
From the Prompt Text field, enter the appropriate text based on the Prompt Title setting.
From the Content Name field, enter a name for your banquet content.
Click the Add button, and then click Ok.
Figure 34-6 Configure Prompt Content Window - Prompt Details
Option 2 – Clicking the ‘Yes’ Button
A prompt asks you to choose the existing configuration prompt to set, or select the prompt content.
Figure 34-7 Configure Prompt Details ‘Yes’ Response
Selecting Yes displays a list of all the existing configuration file names in the Content table.
Figure 34-8 Select Existing Content Prompt
As mentioned previously, selecting No allows you to set the prompts and save details in the Content table. Specify the name of the content.
As shown in Figure 42-6 above, configure the Prompt Type, Dialog Type, Prompt Category, Prompt Title, Prompt Text, Default Value, and then enter a Content Name. Click Add and Ok.
The Optional check-box allows the prompt to bypass the next screen and allows the user to click OK.
There are a number of options when configuring prompt content. Prompt Types can be Configurable or Non-Configurable. Dialog Types include AlphaNumeric, Numeric, List, and by Date. Users must select from the following list of configurable prompt items that can be used for a Banquet Check:
name="lblOrganization" >Organization
name="lblAcct" >Acct
name="lblCustName" >Name
name="lblCustAddress1" >Address Line 1
name="lblCustAddress2" >Address Line 2
name="lblCustCity" >City
name="lblState" >State
name="lblZip" >Zip
name="lblDate" >Date
name="lblTime" >Time
name="lblEvent" >Event
name="lblSalesperson" >Sales Person
name="lblMaitred" >Maitre D'
name="lblGuarantee" >Guarantee
Configurable Prompt Type
The following example illustrates a Configurable Prompt Type. When this type is configured, users are prompted to enter the requested information at the POS workstation—in this case, a selection of function rooms.
Figure 34-9 Configure Prompt Content Window - Configurable Type
![This figure shows the configurable prompt details window and the available settings. This figure shows the configurable prompt details window and the available settings.](img/banquet_check_pg_design_prompt_content_no.png)
Non-Configurable Prompt Type
Non-Configurable prompts are not sent to users when beginning a Banquet Check. Regardless of the assigned Dialog Type (that is, Alphanumeric, Numeric, List, or Date), users are not prompted to enter information.
Figure 34-10 Configure Prompt Content Window - Non-Configurable Type
![This figure shows the non-configurable prompt details window and some example configuration settings. This figure shows the non-configurable prompt details window and some example configuration settings.](img/banquet_check_pg_design_nonconfig_prompt.png)
When configuring a Non-Configurable prompt, and a Default Value is entered, the value is printed on the Banquet Check by default, without any prompts being sent to the user. The following example illustrates a List Dialog Type to provide a list of items—in this case, a selection of cities.
Figure 34-11 Non-Configurable Type - List Dialog Type
![This figure shows the non-configurable prompt details window and some example configuration settings. This figure shows the non-configurable prompt details window and some example configuration settings.](img/banquet_check_pg_design_nonconfig_list.png)
When configuring a Non-Configurable prompt and the user does not enter a Default Value (leaves the setting blank), nothing is printed on the Banquet Check.
Figure 34-12 Non-Configurable Type - Blank Default Value Setting
![This figure shows the non-configurable prompt details window, specifically with a blank Default Value setting. This figure shows the non-configurable prompt details window, specifically with a blank Default Value setting.](img/banquet_check_pg_design_nonconfig_prompt_2.png)
Users may configure Non-Configurable prompts when certain data does not change and remains static in a Banquet Check. For example, if the organization holding the banquet is always the same, it can be defined as a Non-Configurable prompt.
The details and content name added or selected is added as Arguments in the button properties panel.
Figure 34-13 Page Design - Button Properties Panel
The configuration data for Banquet Check prompts is saved in the Content module as a String in the Content Type field, and is shown using XML format.
Figure 34-14 Property Level Content Module
Configuring a Banquet Check Add/Transfer by Number
The following steps illustrate how to transfer one Banquet Check to another.
Select the revenue center, click Configuration, and then click Page Design.
Select the touchscreen page to be edited and add a new button.
Select Function as the Type, select Add/Transfer by Number, click OK, and then click Save.
Figure 34-15 Page Design – Add/Transfer by Number Function
Access and sign on to a workstation.
Begin a Banquet Check and add menu items. Note the check number and service total.
Begin a second Banquet Check and add menu items. Note the check number and service total.
Pick up the first Banquet Check from the workstation Pick Up check list.
Press the Add/Transfer by Number button.
Enter the second Banquet Check number mentioned in step 6. The first check’s prompt data overwrites the second check’s prompt data when the checks are merged.
Press OK from the ‘Add Check’ screen. The second Banquet Check is transferred to the first one.
Configuring a Banquet Split Check
The following steps illustrate how to split a Banquet Check.
Select the revenue center, click Configuration , and then click Page Design.
Select Function as the Type, select Touch Split, click OK, and then click Save.
Figure 34-16 Page Design – Touch Split Function
Begin a Banquet Check, add menu items, and then service total.
Pick up the first Banquet Check from the workstation Pick Up check list, and then press the Touch Split button.
Add a check, move some menu items from one check to another, and then press Save.
Press Yes in response to the ‘Exit and save changes?’ prompt.
Press Yes in response to the ‘Print split checks?’ prompt. The Banquet Check is split and the individual checks can be viewed in the open checks list. The first check’s prompt data is copied to the second check when the checks are split.
Configuring RVC Table Names as Room Names
Select the property, click Configuration, click Employee Classes, select the employee role, and then click the Operator Options tab.
Enable 1- Table Number Entry Required to Begin/Pickup Checks and 2- Number of Guest Entry Required for New Checks, click OK, and then click Save.
Figure 34-17 Employee Classes - Operator Options
Select the revenue center, click Setup, and then select the Tables module (under the RVC Configuration header).
Insert or click an available record, enter a room name (for example, Board Room), assign a Dining Table Class in the Class field, and then click Save.
Figure 34-18 Revenue Center Configuration - Tables Module
Configuring a Custom Page Printer
A Printer driver must be installed on the workstation.
Enter the host name of the printer.
Figure 34-19 Add a Printer on the Workstation
Select the property, click Setup, and then click Printers.
Configure a network banquet printer. In the Printer Type field, select Custom Page Printer from the drop-down list.
Figure 34-20 EMC Printers Module
Enter the network printer name in the Name field, and then click Save.
The Name field entry must be the physical printer’s name as seen on the network and the Printer Host's IP address in the Printer Configuration section’s Address field.Figure 34-21 EMC Printers Module (cont.)
Select the property, click Setup, and then click Workstations.
Select the banquet printing workstation record, and then click the Printers tab.
Click Select, and from the drop-down list, select the output printer in the Banquet Check Printer field (should be the Custom Page Printer type), click OK, and then click Save.
Figure 34-22 Workstation Module - Assigning the Banquet Check Printer
Configuring a Tender Media Deposit
Users can post a Deposit Payment amount on a Banquet Check. If configured, the deposit tender amount prints in a special location on the Banquet Check.
Select the Enterprise level, click Configuration, and then click Report Groups.
Insert a new record, name it, and then from the Type field, select Tender/Media from the drop-down list.
Figure 34-23 Report Groups Module
A Deposit Payment Tender is linked to a Report Group by enabling the 5 - Deposit Type of Tender Media option. From the Options field, click the ellipsis (…) to open the Report Group Tender Media Options screen. Select option 5, click OK, and then click Save.
Users can add an advance deposit payment against the Banquet Check by configuring a new payment tender.
Figure 34-24 Tender/Media - Advance Deposit Payment
Configuring Tender/Media Printing on Banquet Checks
To print a Banquet Check prior to finalizing the transaction, you can create a Tender/Media record configured as a Service Total type. You can also use a Payment type to print a Banquet Check when the transaction is tendered or finalized.
Figure 34-25 Tender/Media - Print Banquet Check Service Total
![This figure shows a Tender/Media Service Total type record used for printing banquets checks prior to finalizing the transaction. This figure shows a Tender/Media Service Total type record used for printing banquets checks prior to finalizing the transaction.](img/banquet_check_deposit_srvc_ttl.png)
Before printing a Banquet Check, select the Enterprise or property, click Configuration, and then click Tender/Media.
Click the Printing Options tab, enable the 90 - Print Banquet Check option, and then click Save.
Configuring Page Margins for Banquet Check Printing
Select the Banquet Check printer record.
Enter the values for the top, bottom, and left margins, and then click Save.
Figure 34-26 Formatting Banquet Check Page Margins
Parent topic: Banquet Guest Check Printing
