34 Banquet Guest Check Printing
This chapter discusses the configuration and usage of the banquet guest check printing feature.
A banquet guest check is used to present a specially formatted guest check for customers. Although it can be used anywhere, the banquet guest check is intended for use in a banquet environment. In this environment, there are additional components of information which can be reflected on a guest check. Information such as the event name, address, contact information, name of the function room the event was held, names of the maitre’d and catering sales manager, and the event’s serving period.
One format of the banquet guest check is available, utilizing an 8.5 x 11 page output which prints on a custom page printer.
Figure 34-1 Example of a Printed Banquet Guest Check
