Adding Non-Revenue Menu Items
Non-revenue menu items can be rung on guest checks while not adding to the net sales total amounts on financial reports. A typical use case for non-revenue menu items, is to use them to enter the value of a gift card reload amount. Operators can add the item to a check and then tender the transaction, causing the item's value to be added to a gift card. This value does not increment the system's revenue since no physical product has been sold.
The following restrictions are enforced on checks including non-revenue menu items on the point-of-sales (POS) system (including Transaction Services Gen1):
Taxes and discounts are not applied to non-revenue menu items (even if they are configured in the EMC).
Non-revenue menu items cannot be included as a part of combo meals. If a combo meal is rung containing non-revenue menu items, the POS generates an error message to users.
Non-revenue menu items can only be configured as condiments for non-revenue parent menu items. Non-revenue menu items cannot be configured as condiments (or combo meal sides) for conventionally priced parent menu items, and vice versa. Incorrect configurations generate an error message to users.
For all workstation financial reports, the previously existing line Non Rev Svc has been changed to Non Rev Total. Non-revenue menu items sales are now posted on the Non Rev Total line on reports.
The existing Menu Item Sales and Menu Item Summary reports do not post non-revenue menu item sales totals. Two new workstation reports have been added to track such totals:-
Non Revenue Menu Item Sales
Non Revenue Menu Item Summary
Configuring Non-Revenue Menu Items
Select the Enterprise level, click Configuration, and then click Menu Item Maintenance.
Click Insert on the toolbar.
Add a master record using your preferred configuration method. See Configuring Master Records for Menu Items for more information.
On each non-revenue menu item master record, enable the Non-Revenue checkbox, and then click Save.
Figure 17-2 Menu Item Maintenance - Master Records
See List of Workstation PMC Reports for more information about the available non-revenue menu item reports.
Parent topic: Menu Item Masters
