Displaying the Order Channel Name on the POS
- Select the Enterprise, property, revenue center, or zone, click Setup, and then click Format Parameters.
- To display the Order Channel Name in the check header on POS pages and in the check header on POS Journal reports, select 65 - Display Order Channel on POS Workstation/Device.
- Click Save.
Parent topic: Order Channels
