Configuring a Manual Start of Day
Important:
When utilizing the manual Start of Day (SOD) system reset methodology, it is incumbent on users to remain diligent and careful about not forgetting to run the SOD for every business date. Failing to do so could result in combining sales totals for multiple days of business on financial reports.-
From the EMC, select the revenue center, click Setup, and then click RVC Parameters.
Click the Calendar tab.
To run the SOD for this revenue center manually:
Enable the Run Manually checkboxes for each day you want to manually execute the SOD.
Click Save.
The Set Business Date equal to Calendar Date if Start of Day configured between 12:00 PM and Midnight option is not supported for SOD’s which are manually executed.
