Holding and Sending Items to Order Devices
The following table describes how to configure the workstation to hold and send menu items on open guest checks to order devices.
Table 25-5 Configure Workstations to Hold Items on Guest Checks
| Task | More Information |
Enable option to hold items on guest checks and add touchscreen buttons |
Enable workstation notifications for held menu items when tendering |
Configure workstations to remind workstation operators of checks with items on hold after signing into the workstation |
Configure guest checks with items on hold to end current service round and add touchscreen buttons |
Setting Checks with Items on Hold to End Current Service Round |
Configure how to handle items on hold when closing checks |
Setting Check Handling with Items on Hold when Closing Checks |
(Optional) Configure Check Screen Look Up (SLU) to display checks with only held items |
Configuring Check Screen Lookup (SLU) to Show Checks with only Held Items |
- Setting the Hold and Fire Option
- Setting the Hold and Fire Tender Notification
- Setting a Reminder for Items on Hold
- Configuring Checks with Items on Hold to End Current Service Round
- Configuring Check Handling For Closing Checks With Held Items
- Configuring Item Hold Buttons
- Configuring the Fire Now Button
Parent topic: Order Handling on Open Checks
