PreviousNext
JavaScript must be enabled to correctly display this content
Setting a Reminder for Items on Hold
Select the Enterprise level, click Setup, and then click Control Parameters.
Click the Configuration tab.
In the Confirm Threshold Period for Items on Hold (minutes) field, enter the time that elapses before notifying workstation operators of checks with items on hold.
If you set the Confirm Threshold Period for Items on Hold (minutes) to 0, the workstation shows a reminder each time a workstation operator signs on to the workstation.
