Setting the Hold and Fire Tender Notification Select the revenue center, click Setup, and then click Control Parameters. Click the Options tab, and then select 66 - Enable Hold and Fire Final Tender Notification. This notification indicates that unfired menu items are on a check during the final tender process. Click Save. Parent topic: Holding and Sending Items to Order Devices
