Setting Privileges for Order Channels
- Select the Enterprise level, click Configuration, and then click Roles.
- Select the role type, and then click the Operations tab.
- To allow users to set the order status to complete on a
workstation:
- Click the Transactions subtab.
- In Transaction Control Options, select 313 - Authorize/Perform Set Order Status to Complete.
- Click Save.
Parent topic: Order Channels
