Assigning Conditional Touchscreen Pages
You can configure other touchscreen pages to appear instead of default pages based on conditions such as menu levels, serving periods, employee class, and other criteria. For example, if the order type is Take Out, display the transaction touchscreen page with take out items and prices called Take Out instead of the default transaction touchscreen page.
- Select the Enterprise, property, revenue center, or zone, click Configuration, and then click Page Assignment.
- Click the tab for the page that you want to add a condition
to:
Login
Home
Transaction
Training Home
Training Transaction
Welcome
Hub
- Select Add in the Page Assignment Configuration section.
- Select one of the following conditions as described in
the following table:
Table 26-3 Conditional Touchscreen Page Names
Condition Available Pages Employee Class
Home Pages, Transaction Pages, and Hub
Revenue Center
All pages
Property
All pages
Workstation
All pages
Workstation Class
All pages
Main Level
Sub Level
Serving Period
Order Type
Visual State
OCB
All pages
Till Assigned
All pages
Combo Side Default Level Activate
Family Group
Major Group
Check Active
Detail Selected
Order Channel
- In the Value column, enter the condition object number or numbers separated by a comma.
- In the Page column, select the page to display when the condition is met.
- Click Save.
Parent topic: Assigning Touchscreen Pages
