API Connectivity
An application programming interface (API) is a set of routines, protocols, and tools used to build software applications. It enables software programs to interact with each other.
In Simphony, an API enables external systems to interact with the
core system to support operations such as:
- Importing into Simphony from an external system
- Ordering from a mobile app
- Exporting employee data for third-party payroll
