Import/Export API
The Simphony import/export API enables automatic import of objects, such as menu items, into Simphony. It also allows export of objects to external systems, such as Inventory Management.
Connectivity to the Simphony Import/Export API is established by granting access to the following example URL: https://ServerName/ImportExportAPI/.
When working with third-party vendors, it is common practice to provide them with the API documentation to facilitate development and integration.
For more information, see the Simphony Import/Export API Guide at: https://docs.oracle.com/en/industries/food-beverage/pos.html.
Parent topic: API Connectivity
