Cable Types
Parent topic: Oracle Networking Expectations
Twisted Pair
The following Oracle MICROS devices utilize twisted pair Ethernet cabling:
- Point of Sale workstations
- Kitchen Display Systems
- Receipt printers
- Kitchen order printers
Consider the following factors:
- Interference from nearby electrical equipment
- Whether Ethernet cabling is shielded or unshielded
- The distance of Ethernet cable runs
Oracle MICROS Expectations
- Properly terminate Ethernet cables.
- Use Category 6 Ethernet cable for final network runs within the building.
- Route Ethernet cables away from devices that generate significant electrical interference.
Parent topic: Cable Types
Fiber Optic
Use fiber optic cable for:
Long network runs that exceed the recommended limits of standard Ethernet cable
Network connections between buildings
Network connections in environments where electrical interference may be a concern
Integrated Device Network (IDN)
Use Cat 6 or higher shielded cables between the patch panel and wall plates to ensure optimal signal quality and reduce electromagnetic interference.
