Network Types
Wide Area Network (WAN)
Select a WAN that:
  • Provides sufficient bandwidth to support the number of workstations at the location.
  • Can scale appropriately during periods of high demand or peak usage.
  • Offers adequate network redundancy and availability to ensure continued operation in the event of an outage.
Local Area Network (LAN)
  • Design a LAN that provides sufficient bandwidth for the number of workstations deployed at the location.
  • Design the LAN to provide sufficient network redundancy or availability in the event of a hardware outage. Ensure robust two-way communication between all workstations.
  • Make and maintain an updated map of the LAN network.
  • Recommend running two cables per wall jack.
  • Use wired network connections for devices that host shared services.
  • Place shared services on highly available devices.
  • Do not place shared services on devices that frequently lose network connectivity, as this can negatively impact POS client operations on other devices.
